New 357 is pinging. Knock sensor pulls timing, how much should I run
Old Feb 17, 2006 | 08:03 PM
jsetzer's Avatar
New 357
Forged Eagle Crank
Forged H Beams
SRP forged pistons 5cc reliefs, gapped .025/.028 with .003 clearance
Deck height is @ .005
Gasket is .039
Cam is cc306
Using calculators I am about 11.7 Static and 8.7 dynamic compression
I have been playing with my tune ALOT the past week. I am stuck with 91 gas.
At first the thing was pulling 5 degrees (max allowed in tune) and that wasn't enough I could still hear marbles.
I pulled 2 degrees across the board and let it pull up to 10 on its own. I don't really see any retard in 1st or 2nd now, but 3-4 punching it will pull timing, I can't hear pinging. In 5 or 6 it will pull the max and I can hear a very little bit of pinging still.
Only see knock at WOT or 85kPa+
Going to try to go get on a dyno tomorrow morning. I may be super lean.
How low can I go on my total timing without sacrificing major power?
Old Feb 18, 2006 | 10:24 PM
jsetzer's Avatar
Re: New 357 is pinging. Knock sensor pulls timing, how much should I run
Ttt
Old Feb 19, 2006 | 06:51 AM
MTBeni's Avatar
Good question, I ould like to know to. I only have bolt-ons but am tuning mine. I keep getting knock retard at the 4100rpm area (100kpa) I have made at least a dozen tweaks to that table and the only way it oesnt knock is if I set the value to 28. Does that seem really low? Mods are in sig
Old Feb 19, 2006 | 10:40 AM
jsetzer's Avatar
You are on your stock bottom end?
Pinging should be less common higher up in the rpm range. But I have seen it higher up myself.
28 is probably going to hurt power. I hate to go that low. I have been pulling a degree or two every day or so. I am still in the mid 30's across most of the board, but want more answers.
Trying to get to a dyno tomorrow. (roads are covered in ice)
Old Feb 20, 2006 | 12:51 AM
1racerdude's Avatar
Go back to STOCK timing and try it. Don't know what stock tables read but a total of 36* across the board is normal for a distributor engine as a starting place.
After going back to stock,if it still rattles take 1/2 a degree out of that block and try it.
Ya may have the fuel messed up too. Go back to stock and leave the fuel alone.
Might be a good idea to get a mail order tune as that set up shouldn't rattle with 92 Octane.
Old Feb 20, 2006 | 08:54 AM
Z28LT1_Just_Nasty's Avatar
Try a mail order tune first and work from that.
Old Feb 20, 2006 | 11:17 AM
jsetzer's Avatar
Don't know if ^^ is directed at me or the other guy but I have a tune from pcm4less and am waiting to hear back from Brian about my problems.
Can't get on the Dyno today because there is salt on the roads.
Old Feb 23, 2006 | 02:28 PM
blkchevyz's Avatar
did you figure out if your too lean?
sounds like you have scaning software, what does your o2 sensors say at that rpms? i know there not acturate, but can get you in the ball park
Old Feb 23, 2006 | 02:32 PM
jsetzer's Avatar
Nope, fried the computer pushing a tune and waiting for it to be socketed and returned.
Old Feb 23, 2006 | 02:52 PM
blkchevyz's Avatar
opps
yeah i did that a while ago, though i had enough juice left lol
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Gtpguy
Jan 26, 2015 04:50 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
jayblev95
Dec 1, 2014 06:55 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
