hesitation problems on cold engine
Old Jan 17, 2006 | 04:48 PM
volZfrk's Avatar
I've searched several threads for a solution and have come up empty so far. 94 LT1 A4, starts fine, idles fine, hesitates, spits and sputters bad on acceleration if engine is cold (never dies). Sometimes has what sounds like a small "backfire" under the hood.
If I start the car and let the engine warm up 5-10 minutes it runs fine with only a slight hesitation on acceleration. I've changed plugs, plug wires, and fuel filter with no improvement. Have not checked fuel pressure yet, but will this weekend. Friend ran a scan on it and it wasn't showing any codes.
Anybody experienced these symptoms? I first thought opti, but figured it would get worse as it got warm or go out all together. Next I'm thinking clogged fuel injector or fuel pump going out.
Any ideas? Thanks, Mike
Old Jan 17, 2006 | 10:32 PM
Re: hesitation problems on cold engine
Have you checked the coolant temp sensor in the water pump housing for accuracy? If its not telling the PCM the engine is cold, its going to run lean until it heats up.
Old Jan 18, 2006 | 03:59 PM
volZfrk's Avatar
No, I didn't even think of that. I'll check it this weekend and go from there.
Thanks, Mike
Old Feb 22, 2006 | 06:07 PM
volZfrk's Avatar
I'm still having this problem after changing out the opti and coolant temp sensor.I checked the fuel pressure and it is good.
I don't know what to do next. Can someone point me in a direction I could be overlooking?
Mike
Old Feb 23, 2006 | 03:01 PM
volZfrk's Avatar
anybody?
Old Feb 23, 2006 | 03:09 PM
blkchevyz's Avatar
what plugs are you running?
Old Feb 23, 2006 | 03:22 PM
volZfrk's Avatar
NGK tr55
Old Feb 23, 2006 | 03:23 PM
blkchevyz's Avatar
Originally Posted by volZfrk
NGK tr55
those are the stock heat range correct?
Old Feb 23, 2006 | 03:26 PM
volZfrk's Avatar
yes
F'n1996Z28SS
Aug 23, 2023 11:19 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
IRABuss
Sep 7, 2011 09:08 PM
