Needing help with plugs and wires
Old Aug 3, 2004 | 12:45 PM
1995greenTA's Avatar
ok all of you out there with headers, when you replaced your plugs and wires, what did you replace them with? some people say over the valve cover wires, but i cant figure out what i need...what should i be looking for? could i just replace them with stock wires from autozone? there is all kinds of different types of wires, different boots, and everything and im really confused, so could some one chime in and give me a hand on exactly what im needing for plug wires to go with Mac mids. Also, when you replaced your plugs, did you just replace them with stock ones? thanks
Old Aug 3, 2004 | 12:58 PM
formula383's Avatar
Re: Needing help with plugs and wires
I replaced mine with the otvc wires and I like them much better. Check out Thunder Racing, they offer a kit for these wires.
Old Aug 3, 2004 | 01:18 PM
z28marine's Avatar
www.thunderracing.com
they have a whole kit for the taylor over valve cover wire kit, around $90.... everything you need...
all the wires are the same length, and the plug ends are not on them.... you cut and put on the plug ends to meet your needs... fast and easy to put on, and no worrying about burnt plugs
Old Aug 3, 2004 | 01:34 PM
Red96Lt1's Avatar
OTVC routes them better with headders.
Old Aug 3, 2004 | 03:28 PM
fesgali's Avatar
When i did headers i went with NGk plugs and Taylor wires. I'm planning on going OTV.
You can't use stock wires cause the will be too short. When you buy the kit the opti end will be on the wires but the plug shoe won't. You'll have to cut the length while placing the wire in it's path over the valves and up to the plugs. If ya need to know how to set up the shoe onto the wire pm me and i'll give ya the detail.
Old Aug 3, 2004 | 03:56 PM
thanks everyone. i finally found the otvc kit at thunder racing. its a little more than i was wanting to pay, but it looks like what im needing. on the plugs, should i go with the same heat range. and should i go with stock gaping? what would be the advantage of going with a higher gapped plug?
thanks guys!
Old Aug 3, 2004 | 04:08 PM
fesgali's Avatar
It doesn't look like your running anythin power adders, so stock should be good.
Old Aug 3, 2004 | 06:49 PM
thanks guys, i ordered my wires and plugs from thunderracing, i got the stock plugs with .050 gap, he said they were stock, but my chiltons says the stock plugs were .035, oh well.. quick question for anyone. do i need o2 sensor extensions for mac mids? thanks again everyone!
Old Aug 3, 2004 | 07:14 PM
Spinner's Avatar
So adjust the gap. No big deal.
Old Aug 6, 2004 | 03:38 PM
i sent you a pm but will send another with specific questions
PCLZ28
Dec 24, 2015 05:19 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
IRABuss
Sep 7, 2011 09:08 PM
mjcent922
Jul 27, 2002 12:42 PM
Zomie
Jul 21, 2002 08:03 PM
