need some help making a 11sec car.
Old Apr 10, 2011 | 08:39 PM
jdelaprida's Avatar
I have a 96 camaro z28 a4.
I have currently a intake and slp exhaust.
I dont want to do nitrous or a torque converter(even though a converter would help) im trying to make a daily driver high 11 street car maybe low 12s.
This is what i was going to do...headers, port and polish heads...a cam 230/236duration 510/520intake and exhaust...1.6rr...3.73s..beehive valve springs...LCAs, panhord, struct tower brace, sub-frame connectors.
Where would that put me and what else would i need to reach what im looking for?
Old Apr 10, 2011 | 09:38 PM
JakeRobb's Avatar
Super Moderator
Re: need some help making a 11sec car.
Sell it, buy this:
https://www.camaroz28.com/forums/sho...d.php?t=806763
Trust me, there's no cheaper way to build an 11-second car than to buy one that's already finished.
Old Apr 10, 2011 | 10:22 PM
jdelaprida's Avatar
thanks but i dont buy i build...
Old Apr 10, 2011 | 10:44 PM
henryz28's Avatar
You are really going to need the converter; unless you build a forged 383 with a small cam and a nice turbo set up. Too much cam will not like the stock stall. Talk the these guys http://elliottsportworks.com/home/?page_id=51 or http://advancedinduction.com/ they can point you in the right direction for a 11 sec car; you will need more than just a high hp motor to get to 11s.
Old Apr 11, 2011 | 04:59 AM
RamAir95TA's Avatar
You don't need AI or LE to tell you how to get into the 11s. All of the info you need is on this forum - just do a search for people putting out those ETs and emulate what they've done. The formula is there, all you have to do is acquire the parts. For example, there's a 4 or 5 page thread a few below this one with tons of good info on how to get into the 11s...read up.
Why are you so against doing a torque converter? It makes absolutely NO sense to go through all of the trouble of doing heads/cam and keeping the stock torque converter - it will drive like absolute ***. If you want to use this car as a daily driver, you'll get a higher stall. I can only wonder why you don't want one - are you afraid it will hurt your drivability? If that's the case you are certainly mistaken. Most of the times people add a torque converter BEFORE they do any engine modifications. Maybe you've never driven in a car with a higher stall before, or perhaps you are misinformed as to how they work, but not installing a higher stall converter will be a huge mistake.
Old Apr 11, 2011 | 06:06 AM
FireHawk409's Avatar
Good set of tires and a well matched trq convertor will help tons in reaching your goal. Also would look into an adjustable trq arm. Strut brace imo isnt really needed.
Sent from my Evo 4 using tapatalk
Old Apr 11, 2011 | 11:05 AM
Mystery Bird's Avatar
A good quality torque converter is a must. Years ago I was afraid to do a converter too. I just had mine reconfigured from a 3000 to a 3600 and the street manors are almost the same. To be honest it drives so nice on the street I wish I went with a 4000.
Old Apr 11, 2011 | 06:11 PM
jdelaprida's Avatar
the only reason i wouldnt want a torque converter is because like i said i want a daily driver and torque converter are gas killers...but i guess if i do want a 11 second car id probably need a converter...but thanks for the info
Old Apr 11, 2011 | 06:24 PM
adam85's Avatar
If you don't cheap out on the converter gas mileage wont be as bad as you think. I would rather loose some mpgs instead of driving with a big cam on a stock converter. Just letting you know from my experience.
Old Apr 11, 2011 | 06:30 PM
Gas mileage will go down slightly during in town driving only, once it locks up it's the same no matter what you get. My car is a daily driver, 18 mpg back and forth to work.
DirtyDaveW
Dec 1, 2016 05:37 PM
grgguy
17
Feb 23, 2015 07:57 PM
ChrisFrez
Feb 22, 2015 08:47 AM
Lonemechanic
Feb 19, 2015 10:29 AM
