Need some good infor about cams/heads...
Old Mar 2, 2003 | 05:47 PM
scyzoryk's Avatar
I dont know too much about that stuff but I want to learn thros ome likns about cams/heads ect...
Old Mar 2, 2003 | 07:11 PM
WJH'sFormula's Avatar
i'm not exactly sure what you were asking, but ill do my best to answer you....
ah, yes.....clarification: cam, as in 1 cam...
cam: this subject is brought up i dont know how many times a day. this depends on your goals and needs... is this your daily driver? are emissions a concern? is gas mileage a concern? do you want 350 or 400 rwhp? etc.... there is a cam out there to fill basically any gearheads need so in order to choose a cam, you must first set forth some perameters and goals for yourself
heads: depending on your specific needs and goals, these may not even be necessary; most of the guys on this board simply get their stock heads ported as the stock LT1 casting is a pretty decent platform for a port job...
next time you have 2 hours to kill, run a search and kick back and absorb as much as you can.
i have a comp xe230/236 cam and ported heads, so let me know if i can answer any other questions
Magenta_Hearts
Mar 25, 2015 10:24 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
