Need quick help? 96 air foil?
Old Mar 13, 2005 | 06:28 PM
Nick-LT1's Avatar
I bought a air foil from my friend with a 95 z28. He had his screwed into his tb. Well i go to instal it onto my 96 z28 and there is no place for the screw? What can i do? Can i just JB weld it in place?
Old Mar 13, 2005 | 09:17 PM
Nick-LT1's Avatar
Re: Need quick help? 96 air foil?
ttt
Old Mar 13, 2005 | 09:53 PM
Eck's Avatar
Eck
There is actually a bolt retainer that needs to be put inside the throttle body. Then you'll have a place to screw it in. Get that from your friend.
Old Mar 13, 2005 | 10:29 PM
DiabloGT's Avatar
Does anyone notice any difference with the air foil? thanks
Old Mar 14, 2005 | 10:19 AM
blackblur1996z28's Avatar
Mine didn't have that bolt either. I just put it in the air elbow..there is a little groove in there that'll hold it straight. No I didn't notice anything from it at all. But I know it can't hurt either.
Old Mar 14, 2005 | 11:11 AM
1-bad-z28's Avatar
So you didn't put it on the TB? You just put it straight up in the elbow? If so, that kinda defeats the purpose of it.
Old Mar 14, 2005 | 11:15 AM
There are a couple different kinds of "air foils". The one the original poster got appears to require a bolt to hold it in the throttle body. The "nut" actually inserts inside the throttle body, under the cover plate. Apparently he didn't get the nut from his friend.
Then there are air foils without bolts. They have little clips on them that are supported by one of the creases in the intake bellows. Yet another kind is a full plastic oval with center divider that inserts into the TB with no bolts or clips.
Problem is, people are talking about 2 different kinds of air foil types.
Old Mar 14, 2005 | 12:23 PM
No..it lines right up to the TB. MIne didn't come with any screws or a nut to attatch it. It's not inside the elbow like in the middle, it's at the end of it
Old Mar 14, 2005 | 02:17 PM
1quikZ's Avatar
do you get any gains by using these?
Old Mar 14, 2005 | 02:31 PM
Not much.....
http://www.ws6.com/mod-4.htm
Old Mar 14, 2005 | 03:38 PM
Nick-LT1's Avatar
mine is the screw in type but there is no place to put the screw what should i do?
Old Mar 14, 2005 | 03:48 PM
1SlowFormula's Avatar
tell your buddy to take it out of his TB and give it to you it will definitly stop it from just rateling around in his TB. If he just un screwed it, and didn't take off the top covere and remove the nut from back there then he should still have it in the TB...
If it got lost before he gave you the air foil, then you need to;
Go to the local hardware store and find a not that will fit the screw,
Also get a big washer that won't pull through the TB,
Then go back home remove the top cover and hold the washer and nut in there while you thread the screw in from the front...
This is easy to remedy, just think about it!
It shouldn't take more then a few minutes to have this done.
94z28jbw
Sep 8, 2002 03:22 PM
ReznorZ28
Aug 27, 2002 03:53 PM
BM93Z
Aug 22, 2002 02:45 PM
turbo_Z
Aug 19, 2002 10:50 PM
NHSZ28
Jul 25, 2002 07:58 PM
