Need piston and rod help
Old Jan 15, 2005 | 04:55 PM
joshp007's Avatar
Exclamation Need piston and rod help
Ok guys I am rebuilding my LT1 but I do not wanna go with a 383. I am boring the block .030 over and was wondering what forged pistons and rods you guys would suggest. Any help is appreciated. Thanks!! I am on a tight budget too.
Old Jan 15, 2005 | 06:38 PM
rskrause's Avatar
Moderator
Re: Need piston and rod help
For a tight budget:
1. Keep the stock rods, have them inspected and reconditioned (if needed) and upgrade the rod bolts.
2. SRP makes a nice moderate price piston in a variety of styles. Diamond and Ross are also nice.
Rich
Old Jan 15, 2005 | 07:05 PM
Seal's Avatar
i was on a tight budget too, here is what happened approximate for just parts
wiseco pistons with rings -500
scat 4340 forged i beams - 220
bearings, gaskets, studs - ~400
new flywheel, balancer - 150
eagle forged crank - 350/400
cam- 250
stock lt1 chain - 20
lt1 heads (2.080 intake 1.650 exhaust with stainless steel valves) - 900
I reused 'newer' stock lifters, and 95 hardened pushrods... already had springs and rockers... engine cost 900 to assemble, and all the machine work costed 600ish
guy is gunna put it in for like 1000 or so hopefully
Old Jan 15, 2005 | 07:56 PM
Ken95Z28's Avatar
Keep the rods upgrade the pistons.
No since of upgrading rods now, looking down the road when and if you go to a 383 you will need to rods than. Pistons I used were some SRP.
Old Jan 15, 2005 | 09:37 PM
joshp007's Avatar
What brand and part number of pistons do you guys recommend as the best for the money?
Old Jan 15, 2005 | 09:47 PM
Seal's Avatar
Alot of people will reccomend SRPs for bang for the buck, however I was told, for just bout the same price (actually wiseco came out a bit cheaper) I would go with Wiseco like myself... do a search on it, I have posted numerous posts on it myself... both come with rings btw....
other good pistons out there are mohley pistonsI believe C5R uses mohley pistons which is like wiseco maybe .... diamon is good too, but i heard wiseco is something right around JE...
for good prices go here...
www.cnc-motorsports.com
there are also probe pistons which are not that expensive... they have a set of very cheap forged pistons which I would take over hypo. pistons anyday...
Here are some links from another board that I was asking around while looking for pistons
http://www.ws6zxr.com/showthread.php?s=&threadid=37030
http://www.ws6zxr.com/showthread.php?s=&threadid=36332
http://www.ws6zxr.com/showthread.php?s=&threadid=37694
Guess it was 600, not 500 heh
Old Jan 15, 2005 | 09:54 PM
captaindbol's Avatar
I just bought a wiseco's and ring set for 409 shipped of off ebay from racers outlet. Also check cnc motorsports as allready mentioned. They are on ebay as well and I've had good luck with them.
Old Jan 15, 2005 | 10:15 PM
joshp007's Avatar
Do I need flat top, dome, inverted?
Old Jan 15, 2005 | 10:23 PM
Seal's Avatar
Are you going FI, nitrous or NA?
if ure going NA, and want to squeze more power i'd go dome
if you are doing FI, then gotta go inverted (or dish)
or if you want just normal pistons, then flat top.... I assume you're going NA, so i'd go with something like 1cc which would make ur compression 11.9-12
or flat top which would make ur compression around 11.1-11.3
I would prefer 11cc dome... that extra compression would be nice...
I'd go with these
wiseco PT001H3 pistons +8cc u'd see around 13 CR
make sure the rod length is 5.7 and stroke is 3.48
Old Jan 15, 2005 | 10:40 PM
joshp007's Avatar
Is stock rod length 5.7 and stroke 3.48? Sorry I am new to this. I am using the stock crank and rods and just want some new pistons and rings
Old Jan 15, 2005 | 10:44 PM
Seal's Avatar
yes, like i stated above...
this is what u gotta get:
bore 4.030
stroke 3.480
Rod length 5.700
that will get you a 355
Old Jan 15, 2005 | 10:45 PM
joshp007's Avatar
Awesome so that will be on a stock block .030 over with stock crank and rods? Thanks for all your help!!
Old Jan 15, 2005 | 10:54 PM
joshp007's Avatar
Hey guys thanks for all the replies, you made it a lot easier on me! Thanks Seal!!
Old Jan 15, 2005 | 10:58 PM
Seal's Avatar
thats right!
obviously ur block will be overbored at the machine shop.... make sure you buy the pistons before u take it to the machine shop for boring, so they can fit them as well....
and np
Old Jan 15, 2005 | 11:00 PM
Seal's Avatar
this woulda been nice (good price too) if they dome...
I guess you can go with flat top, but i would prefer dome for some extra pep
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
