need part numbers asap!!
Old Jul 8, 2003 | 08:03 PM
LS1 bait's Avatar
hey if anyone would know the part numbers for a gm 3.73 gear set for a 3 series carrier or even the part number on a 3 series carrier i real really need it please!im trying to get these gears installed but they r on a carrier already and i want to make sure they r the right ones b4 i tear it apart and dont have parts to put back in it.thanx a lot for all ur help in advance!
Old Jul 8, 2003 | 08:39 PM
There are no part numbers listed for 3.73s for the f-body because they did not put them in from the factory. The part number would have to come out of an S-10 parts book or something which I don't have. If they are GM gears, they should have a GM stamp, number of teeth, part number and ring gear diameter (7-5/8).
Old Jul 8, 2003 | 08:42 PM
LS1 bait's Avatar
ya they r gm gears then but im just trying to make sure they will fit my car....the posi unit they r on is shot and it doesnt have the relucter ring for the abs like my 95 does.so they were in a later model car.i just want to be positive it is a 3 series carrier.do u have the part number for that?
Old Jul 8, 2003 | 08:51 PM
anaik's Avatar
GM does not make 3 series gears for a 2 series carrier.
Old Jul 8, 2003 | 09:09 PM
LS1 bait's Avatar
i know that--that wasnt my question.i am trying to make sure they r on a 3 series carrier.but they r a 3.73 gm gear set by shoebox's description.
Old Jul 8, 2003 | 09:12 PM
anaik's Avatar
Since you know they are GM gears, and since GM doesn't make 3 series gears for a two series carrier, it is safe to assume they are on a 3 series carrier.
Old Jul 8, 2003 | 09:23 PM
LS1 bait's Avatar
i dont know that they r a 3 series gear--i just know they r a gm 3.73 gear set.and i cant find a part number for either gear set.
Old Jul 8, 2003 | 09:27 PM
anaik's Avatar
If they are GM gears they are on a 3 series carrier. Are you reading what I'm writing? GM does not make 3.73's for a 2 series carrier.
Old Jul 8, 2003 | 09:33 PM
LS1 bait's Avatar
u didnt say that b4.maybe u should read what u wrote.
Old Jul 8, 2003 | 10:45 PM
Ok, you guys got all that straightned out?
The only 3 series posi carrier p/n I can find is listed for 1993 - GM PART # 26036755 . That was for GU5 (3.23s) with G80 (posi).
Old Jul 9, 2003 | 08:25 AM
LS1 bait's Avatar
ya if gm doesnt make a 3.73 for a 2 series posi then it must be a 3 series. the part number on them is gm-14092111-11:41-7 5/8. and the pinion gear says gm-11:41. which is a 3.73 when u calculate it.so they must be the right ones.it just didnt match the part number on the only 3.73 gm gear i found a number for which was 14091497.i think the posi is a later yr posi because there is no reluctor ring on it.thanx for ur help.
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
