need opinions on this engine combo
Old Oct 24, 2006 | 08:27 PM
redsick93lt1's Avatar
I am currently building a 355 lt1 to swap into a 86 z28. Now heres the combo- please let me know if there will be piston to valve clearance issues.
355 lt1
speed pro forged pistons
Lloyd elliot stage 2 heads with 202/160 valves and cam
1.6 rockers
5.7 in scat connecting rods.
stock height comp cam hi tech pushrods
cloyes double roller
now the heads were originally on motor for 4k miles and i had brake issues so b4 i put them on new rebuild i am getting the valves checked out. When i tore the motor apart, there was no sign of piston to valve clearance but the car had major brake issues. The engine is going into a 6 spd car so that should take care of that.
Old Oct 24, 2006 | 08:29 PM
and what rings and cam bearings would u guys reccommend. the front cam bearing looks like crap after only 4k miles. I was thinking about coated durabonds and plasma moly rings.
Old Oct 24, 2006 | 08:35 PM
MeanGreen97Z's Avatar
FM bearings always worked before... why change it up? Rings could be sealed power if you are on a budget. Do you intend on running n2o or FI? That makes a difference.
Old Oct 24, 2006 | 09:00 PM
no supercharger or nitrous here all motor
Old Oct 24, 2006 | 09:05 PM
Mogul bearings and sealed power rings are perfect for your combo.
Old Oct 25, 2006 | 12:02 PM
SStrokerAce's Avatar
"the car had major brake issues"
Ok so was it related to idle vacuum? IS that what you are talking about with the brake issues?
If so check for vacuum leaks, set the rockers to zero preload or just barely a little preload and on top of that you want to have the idle set around 900rpm.
bret
Old Oct 25, 2006 | 09:53 PM
yes def a vaccuum issue and originally idle was set at 950
Old Oct 26, 2006 | 01:47 AM
Check for leaks then, that cam without leaks and the proper valve adjustment (around zero lash) will produce more than enough brake vacuum for you. It's usually something dumb like a TB gasket leak.
Bret
oldschool
Feb 9, 2016 09:21 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
97z28k&N
Jan 9, 2015 04:58 AM
1996LT1Z28
Dec 1, 2014 01:01 AM
