Need Oil Pump Information
Old Mar 5, 2008 | 07:51 PM
NemesisLT1's Avatar
I have been gathering information about changing out the oil pump, Alot of the threads are a couple years old, and there was mention of bad oil pump castings by Melling.
Is there still bad castings out there?
Which is the best Bolt-In pump, non High volume.....
I found in a thread that this is what I should get:
Mel-10552 Comes with solid oil pump drive shaft. $61.88
Mel-12558 Bolt on 3/4 screen,Gasket,bolts with locktite. $14.95
7.5" for stock pans
Ill be running a Stock Oil Pan, and the engine will be cam swapped.....
Old Mar 5, 2008 | 08:14 PM
guest74777's Avatar
Guest
i went with the melling select 10554 std volume std pressure, but it does come with a high pressure spring. the regular melling m55 series are a weaker casting and guys have broken them, they come with warnings saying do not use with solid motor mounts. I would just go with the 10554 select, I have excelent oil pressure.
Old Mar 5, 2008 | 08:41 PM
KY95Z28's Avatar
That first part no 10552 is the "select" 10% more volume....You'll want the 10554 as mentioned above. Or just go the the dealer and get the factory pump and a GM "white" high pressure spring.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
