water pump gone - replace opti now too?
Old Mar 3, 2008 | 11:07 PM
silver97Z's Avatar
Ok, my water pump crapped out on me today so it needs to be replaced (it's been leaking coolant from the weep hole for a few weeks now). Should I go ahead and replace the opti while I'm at it, or no? As of now, the opti is working fine. Thanks.
Old Mar 3, 2008 | 11:09 PM
ss.slp.ls1's Avatar
First of all, what year is the car? Well considering they used opti's all the way up til 97 make it at least an 11 year old car, so if it is original, yes change it too. It will be good preventative maintanence.
Old Mar 3, 2008 | 11:18 PM
silver97Z's Avatar
car is a '96 and I've only owned it for 2 months...couldn't tell ya if it's been replaced or not but I don't want to take the wp off again anytime soon...
Old Mar 3, 2008 | 11:21 PM
ss.slp.ls1's Avatar
Well there is your answer. If you can't get in contact with the original owner to find out if the opti is factory, and the budget permits, I would swap it out for a new one. While you are there I would swap out the plugs and wires, it will be much easier. Then you should know that you won't have trouble with that area for a long while.
Old Mar 4, 2008 | 12:13 AM
sbs's Avatar
sbs
If you want to take the most economical route, take the opti off, open it up, and inspect it before making the decision.
But me, I'd just replace it. If it turns out in that situation that the old one looks like new, then sell it.
Old Mar 4, 2008 | 07:00 AM
2000GTP's Avatar
I agree with the others, might as well replace it since you are there anyhow. If the original one looks good, then keep it as a spare, sell it, make a coffee table centerpiece out of it..
Old Mar 4, 2008 | 07:34 AM
silver97Z's Avatar
Originally Posted by 2000GTP
...make a coffee table centerpiece out of it..
Hmm, hadn't thought about that yet...would go great with the wife's flowers
Old Mar 5, 2008 | 08:49 PM
my96z's Avatar
My opti went out and I bought a new waterpump to put on it while it was apart. YOu might as well while you are in there. If nothing else its good preventive maintenance,
Jeff
HectorM52
Jul 30, 2017 11:46 AM
grgguy
17
Feb 23, 2015 07:57 PM
pologreen97z
Dec 2, 2014 10:42 AM
