Need a list....Motor Swap....
Old May 31, 2005 | 10:44 PM
  #16
madwolf's Avatar
Re: Need a list....Motor Swap....
Originally Posted by 94 TA TT2S
Disconnect the brake lines from??? And the braided ground strap is???
There is a braided ground strap from the coil to the body on the driver side.
I disconnected my lines at the ABS unit and the tranny lines from the radiator.
Old May 31, 2005 | 10:46 PM
  #17
94 TA TT2S's Avatar
Cool... Thanks you guys.....Gonna have a lift so it shouldn't take too long...
Old May 31, 2005 | 10:50 PM
  #18
madwolf's Avatar
The torque arm wasn't mentioned I think. It connects with the tranny through a mount.
Dropping is pretty easy, especially with a lift. I did the whole swap all by myself and it wasn't bad at all. The only parts I hated is beleive it or not, lifting the car on those blocks/jackstands and swapping the engines. That was hard doing alone, but everything else wasn't bad.
Old May 31, 2005 | 10:54 PM
  #19
94 TA TT2S's Avatar
Gota lift and few other sets of hands....BTW ION you have a PM
Old Jun 3, 2005 | 11:58 PM
  #20
94 TA TT2S's Avatar
OK guys I worked on it tonight have a few questions.....I got the harness from the top of the motor I noticed that it goes down behin the engine somewhere on both sides...what are these connection??? Do the need to be disconnected??? I noticed in your pic ION that there was not a harness wire anywhere so I am thinking they need to be disconnected....And the tranny lines on top of the tranny do not need to be disconnected??? Just in the front??? And the steering are ...Disconnect it at the top or bottom???
Old Jun 4, 2005 | 11:07 AM
  #21
94 TA TT2S's Avatar
I found out where the two harness wires go...gonna pull them ....Steering arm I am gonn disconnect at the top....tranny line I'm gonna disconnect at the front....
camarolt4ss
May 27, 2011 05:19 PM
aaron_depue
Oct 8, 2010 12:17 AM
Alex IROC Z28
Parts Wanted
Mar 15, 2010 08:54 PM
Sunsetmaro
Jul 25, 2009 03:33 PM
