Need a list....Motor Swap....
I am fixing to a motor and replacing it with a built one and I wanna get prepared for it ...
What I am wanting to get figured out is what all is gonna need to be disconnected ...Everything no matter how obvious it would be...Just in case...
It will be pulled from the bottom so there may be a few more things needed to be disconnected going that route...Thanks Guys
Re: Need a list....Motor Swap....
Going by memory:
Harness inside the car.
Fuel lines.
Power steering hose. (unless you unbolt the reservoir from the body and leave it on the engine)
A/C compressor.
Radiator hoses.
Brake lines.
Sway bar
Cradle bolts
Top strut bolts
Exhaust
Braided ground strap
Tranny cooler lines
That's about it.
Fuel lines.
A/C compressor.
Radiator hoses.
Brake lines.
Sway bar
Cradle bolts
Top strut bolts
Exhaust
Tranny cooler lines
That's about it.
got one
