Need to know my compression ratio...(LE2)
Old Sep 16, 2006 | 12:15 PM
CrazyLT1's Avatar
hey guys,
I am running a LE2 head/cam combo along with a supercharger. The cam was specially cut for a blower. I am currently running a conservative 6 psi. of boost, but I am going for some tuning soon so I want to change the pulley to get the boost as high as I can and still keep it safe.
Details of my bottom end:
Crank: stock GM crank, 24,000 miles on it, balanced, polished, magnafluxed.
Rods: Forged eagle H-beam 6" rods
Pistons: Forged SRP dished pistons with a -24CC dome volume
Displacement is still 350 cu. in.
-according to the srp website, my compression will be 9.0:1 if the head is
58CC. I am using a fel-pro 1074 head gasket also. My question is what is the head CC on lloyds LE2's? is it right around 58, or lower or higher? Is that 9.0:1 ratio right or do you guys think it is lower or higher? Besides the 58CC, they only list the compression for 64CC and 70CC and I know its not that.
Any opinions about what my compression is are appreciated. As well as how much boost you think I could run given my bottom-end set-up and that I am currently making 446 RWHP, thanx...
Old Sep 16, 2006 | 01:57 PM
Re: Need to know my compression ratio...(LE2)
You would need to add deck height and gasket thickness and diameter to calculate the static CR. And you have no overbore at all, with the new pistons? You just cleaned up the stock bores? SRP has no way to knowing any of the basic info about your engine, so a number like 9.0:1 would be a very general guideline.
Didn't you check the head cc's before you assembled the engine? Didn't you calculated the CR with the specific info for your engine, or did you just assume the SRP data was correct?
Old Sep 16, 2006 | 02:40 PM
CrazyLT1's Avatar
Yes it is the stock bore cleaned up - did not need to oversize anything due to the engine only having 24,000 miles on it and being in perfect shape.
I basically need someone who knows about lloyd's heads so I know what the milling was and CC is so I can figure out my exact comp. ratio on my set-up
Old Sep 17, 2006 | 03:45 PM
Did you ask Lloyd?
Old Sep 19, 2006 | 07:17 PM
TransAm396's Avatar
what is the stock deck height on an LT1 block(96) i cant find a straight answer..im pretty much using the EXACT SETUP but 30 over and with a turbo...
Old Sep 19, 2006 | 08:36 PM
CrazyLT1's Avatar
transam396 - your using LE2 heads, -24cc pistons, and stock crank like me?
just curious - i thought I was the only one i knew of with that combo.
Old Sep 19, 2006 | 08:38 PM
TransAm396's Avatar
lol yes. literally..the exact same setup sept my pistons are 4.030 and mines gonna be for a turbo..what blower are you using?
Old Sep 19, 2006 | 08:45 PM
CrazyLT1's Avatar
I am running a Vortech S-trim blower.
Thinking changing to a procharger or even going turbo. the s-trim of mine is almost maxed out. The only thing i am worried about is the 2 bolt main. I heard a stock magnafluxed crank can take a lot, but i dunno about those mains. did you convert to 4 bolt or splay your caps?
I dunno- maybe I should just be happy with around 450 RWHP. But its so easy to be greedy and want more
What turbo are you planning on running?
Old Sep 19, 2006 | 09:03 PM
pgm's Avatar
pgm
Lloyd told me the chambers are usually around 57cc when I had my LE2 heads done. You'd need to get them cc'd to know the exact number.
Did the machine shop deck the block at all? I think the deck height on a stock LT1 block is around 9.030", take that number with a grain of salt though.
Old Sep 19, 2006 | 09:54 PM
TransAm396's Avatar
After getting ported???
Old Sep 19, 2006 | 11:05 PM
2fast97z's Avatar
stock deck height is .015 i think
Old Sep 19, 2006 | 11:07 PM
TransAm396's Avatar
nooo...i hear .020-.030..but i couldnt get a def answer..
Old Sep 19, 2006 | 11:28 PM
pgm's Avatar
pgm
Yep.
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Schul365
Aug 25, 2015 05:47 PM
