Need Ideas..Holley TB throttle stop..
Old Oct 30, 2009 | 06:59 PM
9sevenZ's Avatar
Lookin for ideas to fabricate a throttle stop for the Holley 52mm TB..strange how a 400 dollar TB doesnt have a correctly functioning throttle stop O_o throttle just keeps on going right past WOT lol....any ideas? I have a couple of my own just want to see what other people have done :-) pics would be nice if at all possible
Old Oct 30, 2009 | 09:43 PM
slowride94z's Avatar
http://www.fquick.com/garages/viewga...ewimg&id=92648
http://www.holley.com/data/products/...rge112-504.jpg
mine and the one in the picture have throttle stops. could it be yours is missing a part?
Last edited by slowride94z; Oct 31, 2009 at 09:12 AM. Reason: some how :cool: got in my link
Old Oct 31, 2009 | 12:01 AM
9sevenZ's Avatar
Oh I was meaning a WOT stop...mine goes way beyond WOT actually
Old Oct 31, 2009 | 09:20 AM
in the pictures look at the brass metal piece that the spring hooks too
at the top it has the idle stop at the bottom under the spring it has the wot stop
I went out and checked mine, and this is what comes around and stops the throttle. that and the plastic guard
Old Oct 31, 2009 | 04:14 PM
9sevenZ's Avatar
Here it is at closed position and theres the factory (Holley) throttle stop (circled)
Here it is at WOT
heres the thing, when the factory WOT stop comes into contact with the body (circled above) its already WAY past wide open...probably a good 10 degrees or so. Thats what im trying to get ideas on...fabricate something so it (the butterflies) will actually be horizontal with the bores...not beyond, the factory Holley stop is just so far off it allows the butterflies to go way beyond WOT.
Old Oct 31, 2009 | 09:04 PM
oh I see.
damn now Im gona have to check mine .
Old Oct 31, 2009 | 09:31 PM
9sevenZ's Avatar
Gonna really bang my head tomorrow and come up with something, I'll post up some pics :-)
Old Nov 1, 2009 | 11:44 AM
well I checked mine and its fine, so yours must be defective.
as to a fix you could weld an extra piece of metal to that one or maybe screw an extra piece on. what maybe 1/8" of material or less
or possibly bend the tab more with a small adjustable wrench
if its new Id carry it back and get a new one, and check it first.
Old Nov 1, 2009 | 02:41 PM
Never had that problem with my 58mm Holley TB. However, I did have a problem with the throttle stop piece fitting loosly in the groove machined in the side of the billet aluminum quadrent. There was just enough play to allow the stamped stop lever to move forward and backward in the groove. That caused the closed throttle voltage to vary excessively. I had to pin the throttle stop piece to the quadrent.
If you can't find some sort of defect in the system, looks like you need to super glue a thin shim under the body, where the open throttle limiter hits the underside of the throttle stop screw projection on the body. That will stop the rotation sooner.
Old Nov 2, 2009 | 03:47 AM
madhatter's Avatar
Is this a new TB or old? I had great luck with Holley customer service years ago when working on a carb. Give them a call, they seem to stand behind the product.
PopoFormula
Oct 12, 2015 04:19 PM
truecontr3
Oct 11, 2015 09:30 AM
football4life
Oct 4, 2015 07:48 AM
surreybrad
Sep 29, 2015 09:00 PM
KYWes
Sep 26, 2015 08:49 AM
