Need help with wiring oil scavenge pump and alky pump
Old Nov 17, 2008 | 06:28 PM
RealQuick's Avatar
... which wire are you guys tapping into to get power for those pumps? I assume an ignition wire, but which fuse it in the relay box?
Do I run it this way;
the ignition wire ---> relay ----> ground. Then across the relay is 12V hot (all the time) --->fuse for the pump ---> pump ----> ground?
Sound right?
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Jul 4, 2005 05:00 PM
