Need help with wiring oil scavenge pump and alky pump
... which wire are you guys tapping into to get power for those pumps? I assume an ignition wire, but which fuse it in the relay box?
Do I run it this way;
the ignition wire ---> relay ----> ground. Then across the relay is 12V hot (all the time) --->fuse for the pump ---> pump ----> ground?
Sound right?
Sound right?
stockssn2o
May 25, 2015 08:54 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jul 4, 2005 05:00 PM
