need help with wiring on electric window switches.
Old Oct 4, 2003 | 07:35 PM
ninetythreez's Avatar
the are some blue, brown, & black wires on the small rear panel that plugs into the drivers side window switches. anyone got a pic or diagram that shows which of the 6 wires goes where? Thanks..
Old Oct 4, 2003 | 09:28 PM
Schematic and pic of back of swtich.
Old Oct 5, 2003 | 12:17 AM
thanks!
yu da man...cool..thanks!
Old Oct 5, 2003 | 01:18 AM
so should -abcdef- be wired according to color codes on the schematic?
This may be a "duh" question, but I am NOT an electrician and don't pretend to be, but I would like to fix my switches. The guy who unwired the switches before I got the car didnt know what to do with it all either I guess. The prob I have is the wires are not in the six wire-end holder(the piece in the pic of "back of switch") they should and slide into in the appropriate grooves.\
I am having to rewire the piece in the pic.
Old Oct 5, 2003 | 07:36 AM
Re: .
Yes. that is why I labeled the posts on the switch. Same ABCD... that is in the schematic. Just match the color to the letter.
Old Oct 5, 2003 | 04:44 PM
ok
so I wired it up like the diagram. key on. checked fuse. not working. switches and panel are new. fuse ok. what now?
Old Oct 5, 2003 | 04:46 PM
Use the schematic and check for power and ground where it is supposed to be. Check at the switch and if ok, check at the connector to the motor.
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
warmeck
Feb 2, 2015 12:44 AM
Jazsun
Dec 29, 2014 12:14 PM
