Need help! Walbro pump install, do I have the wrong pump? pics inside
Old Sep 11, 2004 | 12:37 PM
magnumv8's Avatar
I started to install my walbro fuel pump last night, and after seeing the included parts, it doesnt look like it is right. The instructions are for a ford application. There is a rubber gasket that doesnt match anything on the stock setup, the rubber fuel hose is way short looking.
I know these are not supposed to be a direct drop in, but this doesnt look right to me.
Please look at the pics and let me know if this looks like the right parts for an f-body. If so, how do you use the short "s" shaped fuel hose as it doesnt appear to reach from the pump to where the factory line hooks up.
thanks for any help
pics of my walbro
Old Sep 11, 2004 | 02:56 PM
Spinner's Avatar
Re: Need help! Walbro pump install, do I have the wrong pump? pics inside
Generic kit pump. Make it work, or pack it back up, return it, and buy a racetronix.
Old Sep 11, 2004 | 03:50 PM
Fastbird93's Avatar
What he said. Freakin easy install with the Racetronix.
Old Sep 11, 2004 | 04:25 PM
magnumv8's Avatar
I wish I would have just gone with the Racetronix kit now. The problem is that I have had this pump for over 6 months, so returning it really isnt an option.
Old Sep 11, 2004 | 05:19 PM
Fastbird93's Avatar
Doh!!!!
Well, looking at it, the pump should work. what you'll have to do is splice that pump harness in with the stock one, but looking at your pics the one you have should work.
Old Sep 11, 2004 | 07:43 PM
Heatmaker's Avatar
Advanced Member
You have the right kit... all you need to use from it really are the pump, the filter, the hose, and the two clips for it. I just reused the old O ring and pump seal... Works fine saved money. Allot of people on here are running and have fone the same thing... To get your pump bucket back on right use Plastic weld and tape the top and bottom together and let it sit over night. Just e-mail me if you need any help.
Old Sep 11, 2004 | 09:15 PM
magnumv8's Avatar
I picked up some epoxy to put the bucket back together, but I still dont see how that short hose will work. I have held it next to the stock and the only way it reaches is if the spring is bent to bring the pump closer to the upper fitting. Do you just do that to hook it up, then the hose straightens out when the spring releases?? What about using a piece of fuel hose from the parts store?
I just want to make sure this works right. Im sure I can make it work, but I just dont like hacking and modding something just to make it fit.
Old Sep 11, 2004 | 09:50 PM
Heatmaker's Avatar
Advanced Member
THe hose that came with my kit may have been different but I just hooked it right on up...and clamped it in. IF your 100% sure you can't get the hose to work Pepboys has the standard fuel hose available.
Old Sep 12, 2004 | 02:55 AM
Racetronix's Avatar
thanks for any help
pics of my walbro
Wrong pump. You require the F20000169 version in order for the old factory ring to fit the bottom of the pump. The 307 in not recommended for use in the F-LT1 cars when using the bucket.
Wrong filter sock will not fit the bottom of the bucket. The Walbro pumps MUST have a 30 micron filter sock to prevent damage to the gears inside. The factory 70 micron filter sock is bad news.
If you require hose you must use SAE J30R9. Any other type of rubber hose will swell, split and crack in today's gas. This is why we use a flex tube.
Make sure the epoxy you use is gasoline compatible, You would not want the bucket to come apart in the tank.
You will have to splice into the old factory wiring with what you have and use the butt connectors. Inspect the factory male & female terminals on the bulkhead connector for corrosion. This is a very common problem with the older f-body cars.
Old Sep 12, 2004 | 04:21 AM
blwnlt4's Avatar
i say ebay the friggen pump, but thats my 2 cents
Deadbolt24
Jan 19, 2015 01:29 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
omarECD
Aug 19, 2002 07:28 AM
