Need help very fast, trying to remove steering shaft
Old Aug 27, 2004 | 03:32 PM
lt4 fd's Avatar
Hey ive soaked it in liquid wrench and silicone chain lube you know whatever I could find in my garage but it will come out so far then no matter how hard I tug or beat it with a hammer it stops, is there another way to do this or any tips...BTW Im reinstalling the drivers side longtube, also cant remember if the oil filter needs to be removed cause thats bein a bitch too.
Old Aug 27, 2004 | 04:52 PM
lt4 fd's Avatar
Re: Need help very fast, trying to remove steering shaft
is it ok to remove the bolt at the base where it connects to the rack????
Old Aug 27, 2004 | 05:38 PM
RamAir95TA's Avatar
I'm assuming you've removed both the top and bottom bolts, correct? It should be really easy to remove once both are out. Some motivation with a hammer ought to do it.
Old Aug 27, 2004 | 06:17 PM
med_reject's Avatar
all instructions including pics for removing the steering column and shaft can be found here:
http://shbox.com/ignsw/ign_switch_repl.html
Old Aug 27, 2004 | 08:32 PM
Mtrhds94Z's Avatar
Each end of the shaft has a couplings that has a 'pinch bolt'...
Loosen those bolts, slide the shaft up farther onto the 'upper steering column shaft', then remove the lower end from the 'steering box'..
Then take the upper part off by sliding back down the steering column shaft part..
You HAVE to disconnect BOTH ENDS, or of course it won't come off... [it doesn't stretch or compress]
Disconnect the lower bolt too, then pull it up onto the steering shaft, then the bottom end comes off the steering box, then remove it....
And shoebox' page was describing steering column removal, not shaft..
Victor Lamb
Aug 26, 2017 02:52 PM
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Feb 5, 2015 05:14 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
