need help with trouble codes
83- tcc control feedback fault (odm). what is this??
84- 3-2 dounshift feedback fault (odm). shouldent this be for autos only??
63- right o2 sensor failed. this just means i need a new rith o2 right
77- fan 1 fault
77- fan 1 fault
Do yourself a favor..... save Shoebox's code list in your "favorites".....
http://shbox.com/1/Dtcs.htm
The tranny codes have two different definitions... one for the A4 and one for the M6
DTC 83 = Reverse inhibit system (Either the connector is off the reverse lockout solenoid, or the fuse for the solenoid is blown)
DTC 84 = Skip shift solenoid circuit (Same as above, but for the skipp shift solenoid)
DTC 77 = Cooling fan relay control circuit (Faulty relay or blown fuse for the fan circuit)
DTC 63 = Bank 2 (right) Heated Oxygen Sensor (HO2S) Circuit (open circuit) (Loose connector, broken wire, faulty sensor. Switch the sensors side to side and see if the code follows the sensor = faulty sensor; or the code stays on the same side = faulty wiring)
armedtrigger
Feb 24, 2015 08:30 PM
