need help with trouble codes
Old Mar 27, 2004 | 06:20 PM
1FASASZ's Avatar
83- tcc control feedback fault (odm). what is this??
84- 3-2 dounshift feedback fault (odm). shouldent this be for autos only??
63- right o2 sensor failed. this just means i need a new rith o2 right
77- fan 1 fault
Old Mar 27, 2004 | 10:55 PM
Do yourself a favor..... save Shoebox's code list in your "favorites".....
http://shbox.com/1/Dtcs.htm
The tranny codes have two different definitions... one for the A4 and one for the M6
DTC 83 = Reverse inhibit system (Either the connector is off the reverse lockout solenoid, or the fuse for the solenoid is blown)
DTC 84 = Skip shift solenoid circuit (Same as above, but for the skipp shift solenoid)
DTC 77 = Cooling fan relay control circuit (Faulty relay or blown fuse for the fan circuit)
DTC 63 = Bank 2 (right) Heated Oxygen Sensor (HO2S) Circuit (open circuit) (Loose connector, broken wire, faulty sensor. Switch the sensors side to side and see if the code follows the sensor = faulty sensor; or the code stays on the same side = faulty wiring)
Old Mar 28, 2004 | 11:52 AM
1FASASZ's Avatar
so the only code that will affect performance would be 63?
Old Mar 29, 2004 | 12:08 AM
Yes. But isn't it a little difficult to get it in "reverse"?
Old Mar 29, 2004 | 06:25 PM
1FASASZ's Avatar
not really. i guess its a little harder than most cars but its always been like that
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
