Need help on timing chain and waterpump questions
Old Oct 8, 2007 | 03:24 PM
  #16
SS RRR's Avatar
Originally Posted by black96z28
So you say basically stay with the stock set right
I didn't read where you specified your heads/cam combo? What kind of spring pressures are you going to have?
My default answer is if you are going to run higher spring pressures than stock then get a true roller chain like the LT4 E/D. It'll probably cost you less than getting a double roller due to what needs to be done to make a double roller work.
Originally Posted by 96capricemgr
I have heard of more LT4/ED timing set failures than I have stock chain failures.
What type of failure? I've never read of a LT4 chain breaking, but I have heard of the water pump/cam gear problems which never seemed to be the fault of the gears. Shawn, the moderator of the Texas forum broke his stock chain after having to slam on his breaks (six speed) and his engine had 30K miles on it and was stock internal.
Old Oct 8, 2007 | 03:38 PM
  #17
marshall93z's Avatar
That seems weird.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
