Need help. Steering shaft touching header.
Old Apr 12, 2006 | 07:12 AM
96ZCamaro's Avatar
Exclamation Need help. Steering shaft touching header.
Alright well my steering shaft is touching my header. Idk what else really there is to explain, but what all can I do to fix this.
Old Apr 12, 2006 | 07:24 AM
GetaZforgetGT's Avatar
Re: Need help. Steering shaft touching header.
What type of headers?
Check your motor mounts and make sure that they don't need replaced.
A new set may give you the needed clearance if your old ones are sagging.
Old Apr 12, 2006 | 08:20 AM
FastZinTennessee's Avatar
My Hooker Super Comp long tubes are pretty close to the steering shaft- are these the headers you have?
Old Apr 12, 2006 | 08:53 AM
wrd1972's Avatar
My RK's did the same thing. I had to modify it by lengthening the steering shaft to clear the header. I also shifter the column over about 1/4 ". I now have plenty of room with no rubbing.
It just takes creativity to solve these type of fitment issues.
Old Apr 12, 2006 | 09:03 AM
JakeRobb's Avatar
Super Moderator
Whatever you do, don't do what this guy did.
ryanhilsgen
9
Sep 21, 2015 07:34 PM
Aug 24, 2015 06:41 AM
MichiganSkip
Aug 6, 2015 09:38 AM
ducttape1975
Jul 10, 2015 06:29 PM
surreybrad
Jul 5, 2015 10:36 PM
