need help with pushrod length
Old May 16, 2004 | 08:27 PM
BlackbirdWS6's Avatar
Doing heads/cam/headers when my parts come in but I need to order the proper length pushrods. I'm going with the edelbrock heads, cc306 cam XE 230/244 112 and crane 1.6rr's. Anyone know what length pushrods i should get and what kind? Thanks
Old May 16, 2004 | 08:49 PM
ibanez6rg's Avatar
Why not stick with stock length?
Old May 16, 2004 | 09:25 PM
rskrause's Avatar
Moderator
It really should be measured. You will likely be ok with stock length or just a bit longer. If you don't have access to a checking PR, use one of your old ones for a guide. Stock length is 7.200" for an LT1 though.
Rich
Old May 16, 2004 | 09:30 PM
I just wanted to make sure, i guess it wouldnt take long to get pushrods when i need them i assume right? What is the best way to measure them?
Old May 16, 2004 | 10:05 PM
96capricemgr's Avatar
I know at least one of the Impala guys that used the Edelbrock heads needed non-stock pushrods, maybe a quirk to these heads?
Old May 16, 2004 | 10:08 PM
well i emailed edelbrock so hopefully they will get back to me. I will prob just call them because I am impatient anyway. So how do i measure to get the proper length?
Old May 17, 2004 | 04:10 AM
rskrause's Avatar
Moderator
You need a measuring pushrod. The Comp Cams catalog, which is available on-line, has detailed instructions. If you can't find someone to lend you a measuring PR you can use a pushrod of known length (like your stockers) to at least get a ballpark.
Rich Krause
Old May 17, 2004 | 07:45 AM
30thannZ28's Avatar
I JUST finished my heads/cam/rockers etc winter project after nine months and I had my heads milled .010" over and got bigger valves (ferrea 6000 series) and comp pro mag nsa 1.6RR with my cam. (anyways, mods in sig) and I even bought the pushrod length checker and never opened it. I was too anxious to get her running. I stuck with hardened stock length pushrods and behold, they were too long. I now need to spend the extra time and $$$ to get the 7.15" instead of the 7.20" ones.
Point is, do yourself a favor, measure the pushrod length first. Valvetrain geometry is vastly important, and there are too many variables being messed with when you do heads/cam etc.
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
