Valve Spring ?
Old May 17, 2004 | 12:46 AM
SnakeSkinner28's Avatar
Valve Spring ?
Im looking at getting 1:6 rockers for my car and first i was wondering if i should change the valvesprings as well. The motor has almost 100k on it and Im also getting hardend pushrods, so Im probably going to change the valvesprings as well. I was wondering if anyone knows or knows where i can find the specs on how tight to make the valvesprings. Also, how were the results of going to 1:6 rockers for those of you that have done this mod. Im doing all this with a stock cam as of now, so I might not get as big of a gain as those that have swapped cams out. Thanks in advance.
Old May 17, 2004 | 01:27 AM
disco192's Avatar
You can get away with just stock springs, but i would recomend just going with LT4 springs. They are cheap and ge the job done for most cams. If you want to rev higher and get a new cam in the future, i would get the comp 941 springs. They are sweet springs and do not require machining the heads. Im running those springs with a 306 cam and it runs like a beast straight up to 6500 rpm.
Stock cam w/ 1.6 is fine, but why do the job twice if you are doing a cam later.
Should net you about 8-10 rwhp with double roller rockers, even more if you get better springs to handle rpm.
-Stu
Old May 17, 2004 | 08:05 AM
No way I would put 1.6 rockers on a 100k engine and not change the valve springs, but that's just me.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
