Need help with Power Steering
Old Nov 14, 2011 | 09:34 AM
RealQuick's Avatar
Anybody ever make their own power steering lines? If so, what parts did you use?
I am interested in the fitting sizes for the PS pump and the rack.
Jon
Old Nov 15, 2011 | 09:34 PM
Compstall's Avatar
Re: Need help with Power Steering
For what you'd spend on the AN fittings and stainless hose, you could probably buy an OEM replacement for cheaper.
Old Nov 16, 2011 | 05:44 AM
OneShoe50's Avatar
Made one from Russell line, be sure if you are making your own lines use the teflon lined hose and high pressure fittings. Standard -6 line is rubber lined and is rated at about 350psi, where as the line and fittings for power steering are rated around 1500 psi. How do I know? Well when you try to be cheap, you wind up paying twice as much....
Old Nov 18, 2011 | 02:31 AM
97WS6SCharged's Avatar
Hey Jon,
You may want to talk to Rob over at Modular Turbo. He sells a power steering line kit for the LS1 cars and can probably give you an idea of what fittings you need.
Old Jan 3, 2012 | 01:30 PM
RealQuick's Avatar
Anyone else know what the thread sizes are for the fittings in the PS system?
mspennyhughes
Mar 1, 2015 03:50 PM
