Need Help! Please! Read!
Old Apr 16, 2004 | 11:20 AM
LeeS's Avatar
Question Need Help! Please! Read!
Hi Guys!
I have a 1997 Z28 with 80K miles on it.
Question: What did you guys do when you changed you O2 sensor on the Passenger side? How did you get in there to it?
Question: Can changing the passenger side O2 sensor be done without removing the Y-pipe?
Question: Are these sensors hard to get out? Do they usually seize up since they are in the Exhaust Manifold.
Thanks Lee!
Old Apr 16, 2004 | 11:22 AM
Red 95 PITA's Avatar
Kind of the same question here. I found one o2 sensor directly in front of my oil filter. I dont know if its my upper or lower one though. Dealer told me the upper was bad. Anyone know which one i found? and also does the Y pipe need to come off?
Old Apr 16, 2004 | 11:33 AM
Tim240z's Avatar
I cannot give specific reference to a 97, but on my 94, I just went to the parts store and got an O2 sensor socket tool. Looks like a big spark plug socket with a slot cut out on the side so that the wires can be fed through. I replaced both of my O2 sensors with no problem...the driver's side was easy as a wrench could be used, but you will HAVE to use an O2 socket for the passenger side...
Looks like this:
Tim
Old Apr 16, 2004 | 03:06 PM
LeeS's Avatar
Thanks Tim
I really appreciate your help!
I'll get one this evening and change it tomarrow!
Thanks Lee!
Old Apr 16, 2004 | 03:17 PM
Compstall's Avatar
I used the proper sized wrench and got it off.
Old Apr 16, 2004 | 03:23 PM
Tim240z's Avatar
You're a better man than I!!
I even cut the ring side of my wrench (to slip the wires through), and I still couldn't get enough leverage on the passenger side sensor....and it certainly wasn't from lack of trying (or blood)
Old Apr 16, 2004 | 11:46 PM
LeeS's Avatar
Well I'll give it a shot tomarrow and see if I can get it out!
Wish me luck I'm going to need it!
Thanks Lee!
DirtyDaveW
Dec 1, 2016 05:37 PM
ad356
Apr 22, 2015 08:35 PM
aj2494
Mar 12, 2015 10:17 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
