Need help passing CA SMOG
Old Feb 14, 2007 | 02:32 PM
  #16
Running a 195*F t'stat on a reverse flow LT1 might not be a good idea. The stock 'stat is 180*F. Increasing the combustion chamber temps increases NOx formation.
The key is still the fact that it failed on all three.
Old Feb 14, 2007 | 03:50 PM
  #17
lt1hatesme's Avatar
It does have a 160 degree thermostat. Should he consider changing it back to the stock thermostat??
I had no idea that would have an affect on emissions
Old Feb 14, 2007 | 05:36 PM
  #18
93redBirdMan's Avatar
You said its a high flow cat on that car?? I'm almost positive that no high flow cats will pass smog in Ca (for the most part). Cut it out, bolt up an OEM cat, retry the smog test, and come back with results...
Old Feb 14, 2007 | 06:27 PM
  #19
NovaTodd's Avatar
My bad, I thought mine came with a 195 (I have a 180 in it now).
Old Feb 14, 2007 | 11:21 PM
  #20
The lower temp (160*F) t'stat will cause a very slight increase in CO and HC, and a small decrease in NOx. Your problem is well beyond "slight".
Old Feb 14, 2007 | 11:28 PM
  #21
sbs's Avatar
sbs
A good high-flow cat like a random tech usually reduces emissions compared to stock, especially a new high-flow compared to an old OEM.
Old Feb 17, 2007 | 10:49 AM
  #22
lt1hatesme's Avatar
Does anyone know if stock Z06 injectors will fit an LT1?
Old Feb 19, 2007 | 07:31 PM
  #23
lt1hatesme's Avatar
Update
Old Feb 22, 2007 | 01:42 PM
  #24
Original Thread Starter Update:
"Thanks to all who helped. My friend replaced the high flow cat with a "real" cat, and he passed the smog on the first try. Thanks again to all!"
PWNED BY ME, lol i win...
Old Feb 22, 2007 | 01:44 PM
  #25
lt1hatesme's Avatar
In his defense, it wasn't a Random Tech cat lol.
David Dempsey
Mar 12, 2016 12:42 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 8, 2015 12:21 AM
