need help in the middle of header install
Old Jul 16, 2007 | 06:46 PM
ROUDA's Avatar
Im going crazy... Im putting pacesetter longtubes on my 95 camaro. I can not get the air or egr Im not sure what one it is the one behind the motor it has one bolt Im tryed everything I think I stripped it I dont know. van some one tell me how to solve this rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Old Jul 16, 2007 | 07:25 PM
JoeliusZ28's Avatar
i remember i had trouble with this too. i cant really remember how i got it to slip together though, its been a while
Old Jul 16, 2007 | 07:42 PM
ricehammer's Avatar
I had the same problem with my Pacesetter LT's. Turns out the egr flange, that's welded to the tube that connects to the header, is welded in at the wrong angle. I've heard of guys bending the egr tube out toward the fender liner a little bit and getting the clearance they need. I just cut mine off, welded it shut and put block off plates in and did away with the egr all together.
Old Jul 16, 2007 | 08:21 PM
ROUDA's Avatar
I dis connected it from the back of the motor.
Old Jul 17, 2007 | 12:13 AM
Irish350's Avatar
mine wouldnt come off of my manifolds when i put my mac mids on (now switched for pacesetter LTs), so i just sawed it and blocked off the EGR on the drivers side.. the other side is sitting on the manifold.. which is sitting on the sideyard..
Old Jul 17, 2007 | 12:18 AM
camarozz95's Avatar
Same prob. with me i just said screw it after countless hours of trying to make it fit I just bought block off plates and called it a day.
Old Jul 17, 2007 | 12:24 AM
Irish350's Avatar
dont forget the tune
Old Jul 17, 2007 | 07:37 AM
JoeliusZ28's Avatar
wow im surprised no one had any luck with it. i eventually got mine to bolt up, i just had to fanagle with it for a while. I think I might have bolted the EGR up before i tightened the header down. either way, its connected right now... doesnt leak that i know of.
Old Jul 17, 2007 | 11:00 AM
2000GTP's Avatar
My car is an automatic and the problem I had was the EGR tube wouldn't line up with the flange on the header because it was hitting the tranny dipstick. I ended up pulling the header, heating the flange with a torch, and bending it an inch in the direction of the firewall. Problem solved.
Old Jul 17, 2007 | 11:02 AM
ROUDA's Avatar
I have the trany dipstick out.
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
GigaMp3z
Feb 20, 2003 02:57 PM
