350 vs. 383 RPMs
Old Jul 16, 2007 | 10:14 PM
95z28racer's Avatar
350 vs. 383 RPMs
Right now im looking to buy a camaro with a fresh 385 lt1, but for some reason he left the cam and heads stock(i think he didn't have enough money to do a head and cam package). But anyways. I am trying to plan out what i want to do with it but i need to know an average of the rpm at peak power differences with stock motor size vs 385. I was wanting to with le2 or maybe le3 but like everyone else i dont want turn the rpms that the le3 requires at 6800. So about what would it be with 385. guestimates assuming all complimenting parts are there.
Old Jul 16, 2007 | 10:24 PM
thebufenator's Avatar
383 with stock cam and heads?
what did it dyno?
Old Jul 16, 2007 | 10:46 PM
95z28racer's Avatar
I have no idea. he had just got the motor broke in then he got really sick and has to sell the car to pay hospital bills. It has a turbo 350 trans with a 3500 stall and 4.10 rear gear tuned by pcmforless. But when i get it i will dyno it first and post it up on here.
Old Jul 17, 2007 | 10:55 AM
Severous01's Avatar
depends on the valvetrain. mine was tuned and ran stock rev limit, i think 7200 or something. i had a cc306 cam on stock ported heads and 1.5 rockers. ran nice...torque motor for sure.
if you replace the lifters and springs/rockers with those that can handle higher rpm you could possibly get it up to 8k or higher rpm. light weight crank, pistons, and rods, smooth valvetrain and decent heads could get you into higher 8k's.
YOU MUST MAKE SURE that you're system is completely balanced to the highest rpm you are going to hit or you'll kill it quick. balance/blueprint everything.
Old Jul 17, 2007 | 11:01 AM
chrism400's Avatar
The 385 will peak about 3 - 400 rpms lower than the 350. With a stock cam, that thing must be a tire shredder!
Old Jul 17, 2007 | 11:37 AM
95z28racer's Avatar
Sweet just what i needed to know, thanks. Im thinkin LE3 heads and cam are in the near future!
Old Jul 17, 2007 | 12:09 PM
wrd1972's Avatar
Something does not pass the smell test here, even a moron would not go to the trouble and expense of building that kind of short block and not address the cam and heads. At the very least the cam could have been replaced for less than $200.00
Rde Bandit
Mar 21, 2015 10:17 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
Collector Car
Dec 17, 2014 01:12 PM
