sputtering problem.
i second that, a good way to elimenate the wires is to get a spray bottle of water spray the wires down. Then put the car in drive and, while holding the brakes, give it some gas. If the sputtering occurs the wires are the culprit i believe this method should work with the other possible culprits, however, that i cannot guarantee. Good luck.
Nayr
03-03-2023 08:34 PM
