Need help high idle and a few codes
Old Mar 21, 2015 | 04:27 AM
  #16
lt1matt's Avatar
Re: Need help high idle and a few codes
Well P0171 P0174 came back along with P0420 and P0430. I'm wondering if it's possible that the bad cats are giving the O2s false lean conditions?
I'm going to recheck the fuel pressure today after work. Pervious owner told me the fuel pump was replaced. Only thing I don't know is what kind of pump went in the car.
Old Mar 21, 2015 | 04:31 AM
  #17
lt1matt's Avatar
Originally Posted by Injuneer
Appears its maxed out the long term fuel trims, adding 25% extra fuel beyond what it calculates is normally needed. Either the fuel pressure is way low, or there is air entering the engine that is bypassing the MAF. Could also be faulty O2 sensors, exhaust leaks before the O2 sensors, or injectors that are smaller than what the PCM is programmed for.
When checking for vacuum leaks, did you check the bottom of the injectors where they mount in the intake manifold?
Checked everywhere possible for vacuum leaks. used starter fuild and also stethoscope.
I don't see why the injectors would have been changed but what color should they be for my car?
Old Mar 21, 2015 | 07:35 PM
  #18
Multec part # 17124248
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
Gtpguy
Jan 26, 2015 04:50 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
