need help finding switched power source in interior
Old Mar 19, 2006 | 08:05 PM
luckyou03's Avatar
I need a small power source for when the car is on and running from the interior fuse panel. thanks
Old Mar 19, 2006 | 09:39 PM
Re: need help finding switched power source in interior
On the fuse panel at the end of the dash, there is a small square hole, labeled "IGN". Inside that square hole is a 1/4" spade lug. This is a switched power souce, and it is protected by a nearby fuse. Go to Radio Shack, get a crimp on 1/4" female connector, and put it on the wire, push the wire over the spade lug, and you are connected.
Old Mar 19, 2006 | 09:48 PM
1quickTA's Avatar
I wanted to mount a switch in my ash try so I cut the wires that go to the ash try light, ditched the light, and used that power to power my switch. I have also heard that there are some wires that run along the bottom of the center console on the passenger side that are not hooked to anything and provide a good power source. I remember seeing pictures of this somewhere but I have no clue where.
Old Mar 19, 2006 | 09:52 PM
luckyou03's Avatar
Perfect, thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
Jan 23, 2015 01:13 PM
