need help with felpro gasket numbers
Old Dec 9, 2004 | 07:25 PM
tonylittell's Avatar
im rebuilding my engine and im lost when it comes to gaskets..i want to use standard felpro gaskets...nothing fancy but when i look up the numbers im lost as to what i need...can someone help me out and give me the felpro part numbers?
i need as follows
head gaskets
intake gaskets (ported heads)
header gaskets
waterpump gaskets
timing cover gaskets and the seals on the front of it
oil pan gaskets
throttlebody gasket 58mm
valve cover gaskets
main seals
thermostat housing seal or gasket
that is everything i believe
any help is greatly appreciated
i tried a search also and got more confused than before i started
any help with part numbers or where to get these part numbers would make my life a whole lot easier...it is stock bore and compression if anyone needs that information
thanks alot
tony
Old Dec 9, 2004 | 07:42 PM
rskrause's Avatar
Moderator
Re: need help with felpro gasket numbers
I don't have the catalog in front of me. But anyplace that sells Fel-Pro can look it up or you can look on the web www.federal-mogul.com
The following is, however, from memory.
head gaskets 1074
intake gaskets (ported heads) 95580
header gaskets 95585
waterpump gaskets
oil pan gaskets
valve cover gaskets 50293
main seals 40626
That's all I remember, but like I said, rely on the place you are buying or use the Web. They may have a complete set for the LT1, I am not sure.
Rich
Old Dec 9, 2004 | 07:45 PM
hey man what you gave me is better than where i was 20 minutes ago....
thanks alot
tony
Old Dec 9, 2004 | 10:52 PM
MentalCaseOne's Avatar
i need as follows
head gaskets
header gaskets
waterpump gaskets
oil pan gaskets
valve cover gaskets
main seals
thanks alot
tony
Dude
Felpro TCS 45956
Its a gasket set that contains:
2-407 O ring (water pump shaft)
1-14842 Timing Cover Seal
2-35072 Water Pump to Block
1-95579 Timing cover
1-95644 Distribuitor Drive shaft seal (big seal for opty opening)
1-95589 Water Pump Bearing Seal (The first seal from top to bottom)
In short you get the Three seals on the Timing cover itself Water pump drive, Opty and Crankshaft seals (for the three cover openings)
Plus Two little o-rings for the water pump drive shaft and the Timing cover gasket itself made out of gasket material.
The Oil Pan gasket I got from car quest and it has two molded rubber gaskets and two cork oil pan gaskets on the box it has only one number
os32471tc. I am removing my oil pan now so I dont know if its a perfect fit.
I hope that helps
Marvin
Old Dec 10, 2004 | 03:28 AM
thanks man
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
one wicked element
Sep 7, 2002 07:28 AM
