need help on a code
need help on a code
ok my check engine light came on so i went to advance and got it scaned. the code they pulled was p1641 fc relay 1 contol circuit mil requsted. i also noticed that my fuel pressure is on 65 instead of 38.is the fuel pressure related to the code and if so how do i fix it? thanks joe
__________________
__________________
The PCM can not measure or alter fuel pressure. There are no codes for fuel pressure. The problem is not related in any way to the code.
P1641 is for the primary cooling fan relay circuit.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
Jul 8, 2002 01:37 AM
