need help on a code
Old May 27, 2007 | 11:15 AM
30th6's Avatar
need help on a code
ok my check engine light came on so i went to advance and got it scaned. the code they pulled was p1641 fc relay 1 contol circuit mil requsted. i also noticed that my fuel pressure is on 65 instead of 38.is the fuel pressure related to the code and if so how do i fix it? thanks joe
__________________
Old May 27, 2007 | 12:05 PM
The PCM can not measure or alter fuel pressure. There are no codes for fuel pressure. The problem is not related in any way to the code.
P1641 is for the primary cooling fan relay circuit.
Old May 27, 2007 | 01:10 PM
30th6's Avatar
so i guess i need a new pressure regulator?
Old May 28, 2007 | 11:03 AM
...or a new fuel pressure gauge.
Just curious.... do you have an AFPR, and if so, what brand.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
