Need help choosing correct heat range plugs for 383
Old Aug 3, 2004 | 12:24 AM
magnumv8's Avatar
I will be firing up my new 383 soon and am not sure which plugs I need to run. It is 11.5:1 cr, AI heads, 239/245 cam, est. 425-435 rwhp.
From what I have read, I think I should go 2 heat ranges colder.
First, does this sound right for my setup?
Second, I need to know a part number for the plugs. I was looking at the NGK catalog and of course, they only list the stock replacement. I couldnt find any info on what would be a colder plug. From my searches on here, it looks like the TR55 is the stock replacement copper plug. I see others using the TR6. Is this the 2 step colder copper plug?
I really didnt want to ask the parts guys about this because I knew they would just look up the stock plug in the catalog and tell me that is the only one that will work.
thanks
Old Aug 3, 2004 | 12:40 AM
CoUnTryMuZiCZ28's Avatar
Re: Need help choosing correct heat range plugs for 383
I would like to know this also.. forgive my post, just subscribing to the thread..
Old Aug 3, 2004 | 12:44 AM
magnumv8's Avatar
Ussually, I can learn what I need just by reading others posts, but I couldnt really find what I was looking for. Maybe this will help some others as well.
Old Aug 3, 2004 | 12:47 AM
Untill I read your post i hadnt even thought about it..
Old Aug 3, 2004 | 02:12 AM
Mindgame's Avatar
http://www.ngk.com/sparkplug411.asp
go to Numbering System at the bottom of the left-hand sidebar
In TR55, the first "5" designates the heat range..... hottest being "4" and coldest being "7". So 2 steps colder would be a TR75. You'll just have to try it and see how well it works for you. If the plug can't stay hot enough to self-clean then you'll need a hotter plug, maybe the TR65.
-Mindgame
Old Aug 3, 2004 | 04:28 AM
97 RedSS's Avatar
Similiar set-up as me..Ive been running Autolite 104's for a while now and no problems..
Cody
Old Aug 3, 2004 | 07:59 AM
"Rule-of-thumb" is to drop one step on the heat range for each 70HP added. I run an AutoLite 103 (2 steps colder) on a 500flywheelHP 381, when running NA. Like Mindgame said, pick a plug and see how it works in your setup. Too cold and its going to carbon up in daily driving, too hot and its going to burn up in "aggressive" driving....
Old Aug 3, 2004 | 08:11 AM
WS Sick's Avatar
I have been running TR55s set at .035 instead of the factory .050 and it still seems like a hot plug, the plugs stay very clean, but like they were in a blast furnace. If I go down to a TR45 should I maintain factory gap or close it as well?
Old Aug 3, 2004 | 08:34 AM
The 0.050" factory-specified gap is suitable only for platinum plugs. If you use a non-plat plug, you should bring the gap down. How far you bring it down depends on the ignition system and the operating conditions for your engine. I run the 103's at 0.035". But on spray, I use a Champion plug a lot colder than the 103, and gap it at 0.027".
Old Aug 3, 2004 | 09:07 AM
magnumv8's Avatar
-Mindgame
that link was very helpfull. It seems to have a lot more useful info than the catalog.
I think I will pick up some TR75s and see how they work.
Old Aug 3, 2004 | 10:08 AM
Mindgame's Avatar
If the TR55 seems "hot" and you want a cooler plug then you need to go with the TR65 or TR75. The TR45 is one step hotter. NGK's heat range designation goes from "4" being hottest to "7"... coolest.
-Mindgame
Old Aug 3, 2004 | 11:41 AM
WS Sick's Avatar
Thanks Mindgame and Injuneer. I was thinking the first number after the T was the heat range, so the second one is and higher number is colder, got it!!
Old Aug 3, 2004 | 11:50 AM
Mindgame's Avatar
Perry,
My apologies! Please go back and read my last post. I contradicted myself (I don't use the NGK plugs) and got a little dyslexic... so I edited the response. You're right, the first digit designates the heat range. Sorry about that.
-Mindgame
Old Aug 3, 2004 | 11:34 PM
S.J.S.'s Avatar
what kind of negative effects will I have by running the TR55's with the .050 gap?????
DirtyDaveW
Dec 1, 2016 05:37 PM
carl.froehlich
Mar 13, 2015 12:38 AM
sloppytot
Feb 25, 2015 08:30 PM
cristian1311
Nov 23, 2014 02:22 PM
