need help changing the opti 94 ta
Old May 16, 2006 | 09:24 PM
balls51's Avatar
do u have to remove the water pump or what, pain in the a$$, or is there a way that it needs to be done
please help someone
Alex
__________________
Old May 16, 2006 | 09:38 PM
StephenDeli22's Avatar
Re: need help changing the opti 94 ta
Isnt the water pump only 6 bolts? You also have to remove the balancer.
Old May 16, 2006 | 09:50 PM
1clean9c1's Avatar
waterpump,balancer,of the belt.make sure to get waterpump gaskets.you dont want to put the waterpump back on and it leaks down to the opti.
Old May 16, 2006 | 10:03 PM
JP94Z's Avatar
Yep. Water pump must come off. If it's old, you may consider putting a new one on. The A.I.R. pump bracket, belt, and bottom pulley/balancer have to come off too. Good news is the pulley is just three bolts and you can pull it off the hub, which can stay, just needs to be turned so it's like a Y and the opti can pull straight forward and out.
Just try to be patient, rushing through it usually just causes mistakes and lots of grief.
Old May 16, 2006 | 10:47 PM
balls51's Avatar
k thanks for the info lok slike i have an evening job on my hands
Old May 18, 2006 | 12:31 PM
hey01's Avatar
if its your 1st time its going to take alot more then an evening
pull then fans
Belt
drain coolent
pull the balancer
pull coil
AIR PUMP
water pump - watch out one of the bolts on the drivers side will spit **** at you
OPTI
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Sergio
Jan 27, 2016 04:27 PM
grabbem88
Mar 18, 2015 01:25 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
