Need help with cam selection
Old Aug 8, 2003 | 04:04 PM
blackbird007's Avatar
I have all the mods in sig, and am going to get heads thinking about going with Lloyd Elliot, but am looking for the most hp i can sqeeze out without having to change converter and must have excellent street manners as this car is going to be a daily driver. Any recommendations on cams would be appreciated. And one more question what is an LSA and what does changing the LSA effect?
Old Aug 8, 2003 | 04:45 PM
viperkiller's Avatar
you see what i have runs great everybody loves the sound the performance is great if running a stock converter may have a little cam surge at the red light but shouldnt be bad
lsa lobe seperation angle
mine is 112 gives you a fair lope good power curve
110 more lope little more power but higher rpm for peak hp
114 less lope little less power lower rpm for peak hp
as far as cam selection; as long as you have good valvesprings you can run a pretty big lift. ex. i'm running 555 hve had no prob. you may can run a little bigger maybe someone else has tried it
i feel 112 lsa is pretty drivable i realize i have a stall but i dont beleive you need it its pretty bumpy but smooths out right off idle
i highly recomend this cam for a driver
Old Aug 8, 2003 | 10:57 PM
lillbush5555's Avatar
CC306 only way to go
Old Aug 8, 2003 | 11:12 PM
cef97ws6's Avatar
Check out Cmotorsports they just came out with a bunch of new cam options. If your car is for the most part a daily driver I would recommend something like the 224/230 XE cam from comp as the largest for street use. IMO anything bigger and the car gets undesireable to drive daily.
Old Aug 9, 2003 | 07:58 PM
ttt
Old Aug 9, 2003 | 08:04 PM
Cerwin Vega Fan's Avatar
Agrees Or maybe CC305 if you want something less radical.
Old Aug 9, 2003 | 09:39 PM
yorkie's Avatar
I have a 383 and a Hotcam, idle is lopey and kinda rough..
what would be a less lopey cam, more like stock???
Old Aug 13, 2003 | 01:55 PM
ttt
Old Aug 14, 2003 | 02:09 AM
ttt
Old Aug 14, 2003 | 02:24 AM
QCKZ28's Avatar
my xe224/230-112lsa with Lloyd Elliot heads and stock converter with 3.73 gears and pcmforless tuning had lots of surge below 2K rpm. it felt slower than stock from 1500-2800 and then it would put you back in the seat from 3K redline.in my opinion i wouldnt go any bigger than this on a stock stall, its almost unbearable cruising around town unless your turning 2500 rpm.
but remember thats just my opinion
jesse
Old Aug 15, 2003 | 03:18 AM
car_ramrod's Avatar
hotcam?
It sounds to me that you would like something around the size of a hotcam. Im not sure exactly what the numbers are for the hotcam but it wouldnt be easy to find. If its not ground on a 114 LSA you could easily get a custom grind on the 114 to increase driveability. but being so reluctive to change converters is kinda working against you, you'll appreciate your cam much more. actually you'll appreciate your whole car much more with a 2800 stall. just my .02
CR
Old Aug 15, 2003 | 05:33 PM
well i dont want a converter right now as i am not so concerned about how the car launches plus i just got through installing a new tranny and am sick of messing with it
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dec 17, 2014 11:00 AM
Black Sunshine/ 00SS
Jul 29, 2002 11:57 PM
