Need fuel info for LT1...
Old Mar 10, 2003 | 11:21 AM
96z's Avatar
96z
First what is the stock pressure? 42.5 psi?
Secondly what PSI are the SVO's rated at? What is the equivilent at the LT1's pressure?
Lastly what lb injectors would be sufficent for a NA 383?
Old Mar 10, 2003 | 11:34 AM
Stock pressure is 41-47 with the vacuum line off.
I'll let the experts on the subject answer the other questions.
Old Mar 10, 2003 | 11:54 AM
96z's Avatar
96z
Hmmm Shoebox you provoked another question. I have a walbro 255lph intank pump also..Would this effect the pressure?
Old Mar 10, 2003 | 11:57 AM
AlexA's Avatar
It did with mine. FP went to 46/50. Bought an aeromotive FPR to bring it down.
As for what injectors, it depends on your power levels and rev range. 30s are good but could be close depending on revs, FP, and power. 36s would probably cover most applications.
-Alex
The stock RP's are rated 24.9#/HR @43.5psi (=3.0bar). The SVO's I have seen are generally rated at 2.7bar = 39.15psi. Running a 2.7bar injector at 3.0bar will increase the flow rating by 5.4%. A 24# SVO should deliver 25.3#/HR, assuming it was really rated at exactly 24#/HR. But some injectors are flow rated in grams per second, which causes them not to be exactly a "whole number" #/HR.
Old Mar 10, 2003 | 12:41 PM
96z's Avatar
96z
Thanks for the conversion Fred.
Its interesting Alex that, that happened...if so I might be able to get away with a 30lber than for 500+ HP.
Sauced
Mar 29, 2015 10:53 PM
InfernalVortex
Jan 17, 2015 09:35 AM
30thZ4C
Dec 26, 2014 05:09 PM
bernie1951
Dec 10, 2014 10:03 AM
