need a double check here
Old Apr 7, 2006 | 12:45 AM
tritonium's Avatar
For the Valve train -
About to start rebuilding my short block finally!!!!!!
any helpful tips ( LT1 ) that i wouldent catch - im using the LT1 /LT4 book
So
Summit Part Numbers
For the valve train:
CCA-7808-16 - Pushrods ( Should i use a pushrod length checker first? Or should i just go with these - I will be using stock lifters that have 140k on them as long as all the bearings are in good shape will be checking on a piece of glass soon.
(I have guideplates)
ARP-135-7101 - Studs
CCA-1305-16 - Rockers
Assembly lube - CCA-104
Please let me know if all these will work -if not please reccomend something else- thank you sooooo much!!!!
-Brad-
Old Apr 7, 2006 | 12:54 AM
tritonium's Avatar
Re: need a double check here
Mod Please Delete This Post - It Double Posted - Odd - Sorry Anyway.
Old Apr 7, 2006 | 06:10 AM
I deleted the other one. You can delete your own posts at any time. Click the "EDIT" button and there is a "DELETE" option.
grabbem88
Mar 18, 2015 01:25 PM
captcorvette
Mar 7, 2015 12:37 PM
grgguy
17
Feb 23, 2015 07:57 PM
ModdedNerd
Jan 29, 2015 07:23 PM
squarehead
Jan 15, 2015 07:02 PM
