Need a detailed procedure for converting Opti
Old Aug 2, 2006 | 12:57 PM
money pit's Avatar
I need to know step by step what needs to be done to convert from the 93-94 non-vented, to the 95-97 vented style. I have read a little here and there but have not fully understood it yet.
Old Aug 2, 2006 | 01:14 PM
madwolf's Avatar
Re: Need a detailed procedure for converting Opti
You will need a new cam, or you will need the dowel pin taken out of the old cam and a new one installed.
You will need a 95 timing cover, vented intake elbow (you can probably drill a hole through yours if you don't want to spend the money), vented opti, vented opti harness and vented opti vacuum tubes.
I actually have most of the stuff, minus the opti for doing this. I will be selling it soon in the for sale section.
Old Aug 2, 2006 | 01:44 PM
anaik's Avatar
Here's a link with pictures.
http://para.noid.org/~muttvette/opti.html
Or you can get an MSD opti for '93-'94 that's vented
Old Aug 2, 2006 | 02:05 PM
WS Sick's Avatar
It's also a good excuse to upgrade your cam
Old Aug 2, 2006 | 03:00 PM
money pit's Avatar
Good start. Thanks guys.
Old Aug 2, 2006 | 03:27 PM
...or you can just buy a new MSD opti with the spline drive, that is also vented. Nothing else to change, just add a fitting or two for the vent system.
Old Aug 2, 2006 | 03:44 PM
WS Sick's Avatar
Unless you get the cover for the 95 style and all the rest used the new MSD opti is really the cheapest route.
Old Aug 2, 2006 | 05:23 PM
Mtrhds94Z's Avatar
You need a different cam, not just a longer dowel pin..
A lot of people seem to forget about the nose drilling for the later opti that the 93-4 cams don't have..
Old Aug 2, 2006 | 06:38 PM
Dave89IROC's Avatar
agreed, the hole in the snout is larger on the 95+
Old Aug 2, 2006 | 06:42 PM
madwolf's Avatar
...some people just don't appreciate a good challenge.
Old Aug 2, 2006 | 06:43 PM
Dave89IROC's Avatar
lol
and you will need a vented opti timing set
as you can see, it adds up quickly, it will be easier and probably cheaper to get the MSD opti for the 93-94 cars
Old Aug 2, 2006 | 08:18 PM
money pit's Avatar
Quite a bit more involved than I thought it was. I'm just trying to get this car running right so I can sell it. I'd love to keep it but not enough cash, we all know how it goes. Thanks for all the help.
Old Aug 3, 2006 | 08:23 AM
Severous01's Avatar
Accell has a new one out now too...it's only about 235 and you can get it for either the 93, 94-5, or the 95-7 model cars. it's vented, plated, and epoxied so it wont retain water or corrode.
MADWOLF:: love the avatar...it's cool :-P
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
thenewkid
Apr 12, 2015 07:42 PM
ChrisFrez
Feb 15, 2015 07:49 AM
