Need cam info for XE 227/233
Old Jul 13, 2005 | 01:01 PM
ford's Avatar
Need to know the intake/exhaust lift and intake exhaust duration @ .50" with 1.6rr's
i think intake exhaust lift is .560/.569? but is that with or without 1.6 rr's
Old Jul 13, 2005 | 01:10 PM
1racerdude's Avatar
Re: Need cam info for XE 227/233
Call Comp Cam's,I bet they would know.
Old Jul 13, 2005 | 01:21 PM
Built on Sin's Avatar
Lift is .560/.569 with 1.6 ratio rockers.
Old Jul 13, 2005 | 01:25 PM
ford's Avatar
Anyone know the duration @ .50"?
Old Jul 13, 2005 | 01:31 PM
ford's Avatar
ive actually been on hold since i posted this.......
Edit: they had no clue :/
Old Jul 13, 2005 | 01:34 PM
BUBBA's Avatar
What engine are you talking about?
Old Jul 13, 2005 | 01:41 PM
ford's Avatar
Uhhh.... LT1? Why else would i post in this section?
Old Jul 13, 2005 | 01:47 PM
BUBBA's Avatar
Well, "ford"--anyway, when you say 227/233 what are you talking about?
Duration at .50 lift with 1.5RRs or what? Do you know which XE cam you are talking about--they have part numbers.
Need more information. Perhaps it is a custom grind?
Getting the specs on an over the counter cam is easy, if you know the part number, but if it is a custom grind you will need a lot more than the duration.
JMHO
madwolf's Avatar
You posted the duration... 227/233. Not sure what you're asking.
Old Jul 13, 2005 | 01:52 PM
ford's Avatar
Bah i forgot that was the cams duration... I guess i now know what i need to know.
Oh and "Bubba" --- i dont know the actual part #, i just know that its a XE 227/233 :/
Ford is my name, not what car i drive.
Thanks Ion
Old Jul 13, 2005 | 01:54 PM
madwolf's Avatar
That custom grind is sold by combination motorsports only, as far as I know. You can order it directly through them if you want it.
Old Jul 13, 2005 | 01:57 PM
BUBBA's Avatar
ok. Just never heard of a comp cam XE with 227/233, but hey...
Old Jul 13, 2005 | 02:42 PM
BUBBA's Avatar
The 227/233 is an off-the-shelf cam offered by combination motor sports and is ground by Comp. Lift 560/569 on 114. If this lift is with 1.5s it would be with a lobe lift of 373.3 IN and 379.3 EX or 597.28/606.88 w/ 1.6rrs.
Old Jul 13, 2005 | 02:51 PM
BUBBA's Avatar
Those lifts are are with 1.6RRs. I.e. 560/569 with lobe of 350 /355.62. With 1.5s it would be 525/533.43.
rideordie
Nov 5, 2019 04:52 PM
chuyz28
Jan 15, 2015 04:14 PM
bernie1951
Dec 10, 2014 10:03 AM
Queens94z28
Nov 20, 2014 06:03 PM
Elcojoe
Nov 17, 2014 10:27 PM
