Need advise on 2 bolt or 4 bolt main..
I did a search and didn't come up with anything conclusive. Will a 2 bolt main block be good enough for a 400ish rear wheel horsepower LT1 w/ a 125 or 150 shot of spray?? Or should I go with a 4 bolt main??
Your gonna find both opinions on that. If any doubt 4 bolt splayed is the way to go. You can save cash, but if it makes the motor more solid and less flex prone by the crank, that in itself can save your bearings and make them last longer. You can get by with 2 bolt main as well several people have done it. Your gonna have to research and research until you come up with what is going to work for you.
Agreed the 4bolt vette block is stronger, but not as strong as a converted 2bolt. I would for sure go with the the 2 bolt block and get it converted if your set on 4 bolt.
Not necessarily true. GM knew the LT1 block would be used with STRAIGHT 4-bolt mains, and appear to have put the meat in the block to support it. That's based an an analysis done by a shop that has built more than one 1,000+HP LT1 engine. They preferred a stock 4-bolt block (with upgraded caps, etc, obviously) and had their most successful LT1 build (1,125HP 383 running 20+ # of boost) with a factory STRAIGHT 4-bolt block, and no fill.
I just installed a new oil pump today and discovered my LT1 to be a factory 4-bolt main. It is a replacement motor by previous owner and was hoping that it was a 4-bolt. So that means then that I have the stronger block? Are the 4-bolts less prone to spinning a bearing vs a 2-bolt, due to the stronger support?
A 4-bolt BLOCK isn't stronger - no matter whether you drill holes for straight bolts or splayed bolts, you are removing material from the block webs, and weakening the block. The advantage in the 4-bolts is strengthing the caps and improving the register on the caps.
Victor Lamb
Aug 26, 2017 02:52 PM
Sergio
Jan 27, 2016 04:27 PM
