Is it necessary to use distilled water in the cooling system?
Old Jun 15, 2005 | 01:17 PM
KillerTA's Avatar
or can I just use regular city water out of my hose?
Also, how many gallons of coolant should I buy when I flush it out?
Old Jun 15, 2005 | 01:19 PM
TruDualed95Z's Avatar
Re: Is it necessary to use distilled water in the cooling system?
I used tap water with no problems.
Old Jun 15, 2005 | 01:23 PM
Charging TA's Avatar
Distilled does not corrode as fast, it does not have the impurities as tap does...
We use Distilled water in our Karts, the engines alone cost more than some cars on this site.... and we flush the systems continually...
Do you need that in your car? I highly doubt it, unless your going to be flushing it once a year or more frequently... I dont see a problem sticking with tap.
Old Jun 15, 2005 | 02:43 PM
OBE1 95Z28's Avatar
Cheap insurance to keep your coolant system happy. Two gallons of coolant should cover you.
Old Jun 16, 2005 | 02:11 PM
slopokrodrigez's Avatar
Ever see the white corrosion form in a coolant system? That won't happen using distilled water. Unless you cut it with battery acid. LT1's have enough cooling problems don't you think?
Old Jun 16, 2005 | 05:00 PM
Deckstripes's Avatar
I know people that swear by distilled in the cooling systems, but I've only started recently. And the only reason I did is that I don't like the water quality where I live now. So it probably depends on if your ground water is hard or soft to start with. The harder the water, the greater the need for distilled. Also- if it's a project that will get the coolant changed regularly due to repairs or maintenance, then tap is probably fine. But if the coolant is in there for 5 years at a time, then it's worth the distilled. Good Luck!
Old Jun 16, 2005 | 06:02 PM
tom2's Avatar
I use water out of the dehumidifier, hard to get more pure than that.
Old Jun 16, 2005 | 06:05 PM
RCF925's Avatar
I don't use any water, Just Evans NPG+
Old Jun 16, 2005 | 06:48 PM
Cerwin Vega Fan's Avatar
distilled here.
Magenta_Hearts
Mar 25, 2015 10:24 AM
grgguy
17
Feb 23, 2015 07:57 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
