My LT1 EFI Connection Dyno
Old Sep 12, 2010 | 12:12 PM
SS MPSTR's Avatar
Just had a new cam installed, along with a TH400/trans-brake/5000RPM converter and an LS1 pcm conversion (no opti/single coil any longer). Tuned locally here. Thought I'd share the numbers.
385 CI, 12.4:1 SCR
AI LT4 heads/intake
HR cam 246/254
Coan TH400/5000 rpm Coan Converter/t-brake
12-bolt/4.10 spool
Old Sep 12, 2010 | 01:45 PM
That's excellent with the TH400, 12-bolt and 4.10. With same setup, I measured 19.8% drivetrain loss at the 400rwHP level. My stall isn't as high, posi in place of the spool, and it was a non-locking converter. If you had similar losses, you would be at 525HP at the flywheel.
Old Sep 12, 2010 | 10:13 PM
neil350's Avatar
That set up is making some awesome numbers
Old Sep 13, 2010 | 04:44 PM
funina91ss's Avatar
Nice setup. Any pics of your coil install?
Old Sep 13, 2010 | 07:51 PM
Rob94hawk's Avatar
Nice! So tempted to get this EFI system especially since I have no one local that can do an LT1 tune and not thrilled with mail order tunes. But there is Kaltech a few miles down from me that does dyno tunes.
Are you using a single or double roller? I've got a double roller and I've been told that EFI has a billet timing cover to fit double rollers and their reluctor wheel.
How easy was the harness install?
Wow! That's some serious driveline loss! What's the percentage with a T56 and a stock 10 bolt with 4.10's?
Old Sep 13, 2010 | 10:40 PM
Dave1980's Avatar
Harness install was cake for me. I dont know about anybody else. I bought mine pre made however. Congrats on the #'s throught that auto SSMPSTR. I am loving not having to worry about ignition problems with this setup. My tuner even said he could tell a difference in how it runs and the mannerism of the vehicle.
Old Sep 14, 2010 | 02:38 AM
ak95ta's Avatar
Congrats on the nice #s. PM sent.
DirtyDaveW
Dec 1, 2016 05:37 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
chevysam
Jan 16, 2015 07:45 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
