My LE ported AFR 190 head numbers
Old Dec 30, 2005 | 11:26 PM
Honda Hunter's Avatar
.2 138/107
.3 194/143
.4 242/178
.5 274/199
.6 285/211
.650 288/214
They have a 216 cc intake port as opposed to the 187 cc intake port (claim 190 cc) that they start with.
How are these numbers?
Old Dec 31, 2005 | 12:23 AM
Zigroid's Avatar
Re: My LE ported AFR 190 head numbers
they look good. seeing all the new stuff lloyd puts out makes me wish I waited longer to get my heads done! his products just keep getting better and better.
Old Dec 31, 2005 | 08:53 AM
one and only ttt.
Old Dec 31, 2005 | 10:55 AM
MEAN LT1's Avatar
Good numbers man!. I do havea question though, seeing all the le3 ported stock heads and then looking at your afr 190's. they almost look the same?. I understand flow nuumbers only mean so much. But was it worth the money for the afr's?.
Old Dec 31, 2005 | 11:12 AM
Actually I was thinking the same thing which is more or less why I made this thread to confirm. I didnt buy these heads new. I got scammed bad on my last motor and when it was all said and done these heads were all I had left over worth anything. In the end though I think I will be happy with these LE ported heads on my 383. Cant beat the great customer service. If I make 420+ and run good times Ill be happy.
Old Dec 31, 2005 | 11:25 AM
blackz97's Avatar
The exhaust side of those AFRs flow WAY better then the LT1 castings.
Steve
Old Dec 31, 2005 | 11:57 AM
NightTrain66's Avatar
from a quality stand point, the AFR and TFS heads are thicker EVERYWHERE.
These heads can be opened up larger in key areas and shaped certain ways that will work better and make more power on a high RPM 355 or ANY 383. It is just something that a 28" flow test doesn't show.
The milder the set up, the better the LT1' castings are gonna do but the more power you start making, the more increase you will see with these TFS/AFR heads.
Lloyd Elliott
972-617-5671
Eportworks.com
Old Dec 31, 2005 | 12:05 PM
Lloyd Elliott
972-617-5671
Eportworks.com
I never had the change to thank you for the work. Heads I believe should be here any day now and Im sure Ill be happy with the performance. I hope to do business with you again and I'd reccomend you to anyone in the gulf.
Old Jan 3, 2006 | 09:16 AM
WS Sick's Avatar
Well considering you gained in numbers 20 CFM almost accross the board from the out of the box AFRs I'd say that is awesome!!.
I'll bet like Nightrain said though , the numbers probably do not give the heads justice.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
