tricks on intake manifold
Old Jan 2, 2006 | 08:59 PM
twiztidglory's Avatar
hey im pulling the intake manifold off the lt1 and was woundering if you have any tricks about getting it off, i am in my house garage and cant seem to pry it off. dont worry i wasnt really "prying". i have hit it with a hammer and 2x4 but i dont think i have a big enough hammer.
Old Jan 2, 2006 | 09:02 PM
94Camaro_Z_28's Avatar
Re: tricks on intake manifold
Just make sure all of the bolts are off of it and that the steam pipe running down the passenger side is out of the way. I used the handle of a hammer inside the front of the intake(throttle body removed) to coax it up. Also, the EGR pipe runs from the passenger side exhaust manifold into the intake on the rear. This is a flex pipe so you will have room to move the intake around so you can get to the bolts to remove it.
Old Jan 3, 2006 | 12:38 AM
3gc's Avatar
3gc
Just make sure everything is unbolted and disconnected. You should be able to pull it up with a good yank. I had to climb on top of the engine and give it a good pull to get it loose. Good luck.
Old Jan 3, 2006 | 09:30 AM
1quickTA's Avatar
Like they said, make sure everything is disconnected, and then pry it off. I took my throttle body off and put a wood handle (i think it was from an axe) into one of the holes and gently pryed. Came right off, nice and easy.
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
