This is my LAST Jet-Hot LT question I swear fo lawd!
Old Jul 8, 2003 | 08:49 AM
CrippleFightin's Avatar
Ok with the drivers? sie header, there is the tube that disconnects from the rest of the header. Do i need to weld this, or is it supposed to come off at will? Installing this weekend and I need to be clear on it.
Mike
Old Jul 8, 2003 | 08:53 AM
joeSS97's Avatar
That comes apart so you can install it without removing the steering shaft.Dont weld it.It should be a tight fit.Probably have to knock it together with a mallet.
Old Jul 8, 2003 | 10:54 AM
kmook's Avatar
Advanced Tech Moderator
^ What he said, you do not need to weld it.
Old Jul 8, 2003 | 05:30 PM
Thanks for the help...its always appreciated.
Old Jul 8, 2003 | 05:45 PM
doodad's Avatar
Had to dremel out mine, and the y pipe junction frame piece, and the cross member. Dont ask about the air weld that blew..
Magenta_Hearts
Mar 22, 2015 03:36 PM
mspennyhughes
Mar 1, 2015 03:50 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
KASR_Z28
Aug 6, 2002 03:34 PM
